[GRASSLIST:3662] Re: moving window bigger than 25 cells
Carlos Henrique Grohmann
guano at usp.br
Mon Jun 14 17:37:41 EDT 2004
You can convert your data to sites and use s.cellstats. the size of the window
will be set by your region settings.
Carlos Henrique Grohmann - Guano
Geologist M.Sc - PhD Student at IGc-USP - Brazil
Linux User #89721 - guano at usp dot br -
Citando Glynn Clements <glynn.clements at virgin.net>:
> Thomas Hoffmann wrote:
> > I need to calculate max, min and mean values within a moving window with
> > a window size bigger than 25 cells (which is the upper limit for
> > r.neighbors). Does anybod know some advice?
> If you have the source code, delete the following line:
> parm.size->options = "1,3,5,7,9,11,13,15,17,19,21,23,25" ;
> from src/raster/r.neighbors/cmd/main.c, then re-compile and
> re-install.
> I'm fairly sure that there isn't any practical alternative.
