[GRASSLIST:3671] Re: v.extract (5.7) doesn't work on extra fields?
William K woklist at charter.net
Tue Jun 15 15:05:05 EDT 2004
>>> 3) > v.extract -d in=tgr out=tgrzip type=area,centroid field=4
>>> list=1-99999
>>>    This is wrong as it groups areas by category, not by ZIP.
>> so v.extract -d works purely on categories?  I guess I was thinking
>> that cats were like a table relate to the fields, and it would use the
>> field columns (minus the cat).
> 'list' and 'file' works on categories, 'where' works on attributes.
so if I used: (assuming the tables are sorted correctly so that _2.cat
= _3.cat)
field=3 where "ZCTA != ''"
would it also dissolve by ZCTA?  or just select?  I tried where once
with no luck, but I was selecting on the cat column (where "cat > 0"),
so of course there was no difference.  Or maybe not because ZCTA5 is
varchar?  oh, that's probably why you did the whole reclass thing in
the first place - dissolve only works on the cat.
oh, but that would be nice for dissolve...
>>> 4) There was a bug in v.extract -d, I fixed that in cvs.
>> I'm using CVS snapshots (2004-6-5 at that time).  I had heard about
>> the
>> bug fix and wanted to try it out.
> It was fixed today.
huh, I thought I saw it mentioned a couple weeks ago.  maybe you were
just talking about fixing it and I jumped the gun.
well, I have stuff to keep me busy, so I'll just wait for the next
snapshot.
William Kyngesburye <williamk at mappingspecialists.com>
Mapping Specialists <http://www.mappingspecialists.com>
Don't Panic
