[GRASSLIST:3715] Re: gnu software for digitizing
Benjamin Ducke
benducke at compuserve.de
Fri Jun 18 13:24:53 EDT 2004
I would give the JUMP program suite a try.
It is very nice software written in Java and completely free.
It has tools for creating vector maps that exceed MapInfo in
many ways and can output Shape files or load/save from a
PostGIS SQL database.
However, if you want to use raster layers, you
have to set up an WebGIS server, such as the UNM Map Server
(http://mapserver.gis.umn.edu/index.html) and connect to it from JUMP.
JUMP does, unfortunately, not support direct loading of
raster layers from file (as far as I know).
http://www.jump-project.org/
Benjamin
On Fri, 18 Jun 2004 11:50:25 +0000
"juan pablo perez" <valdentro at hotmail.com> wrote:
> Hi
> I'm working with my pupils with GRASS (developping several DEMs) and they
> have problems because v.digit is not as friendly as is MapInfo (as a first
> module we worked with it)
> Is possible to work whit another gnu-program that supports raster images and
> layers to digitize contours and export them (e.g. as *.dxf) into GRASS?. I
> tried with The GIMP, but it don't exports in vector format; also tried with
> QCad, but it has not support for raster layers,...
> Can anybody help us?...
> _________________________________________________________________
> Reserva desde ahora tus vacaciones en MSN Viajes. Más cómodo, más barato y
> más opciones. http://www.msn.es/Viajes/
