[GRASSLIST:3724] Re: Error in NVIZ
temiz
temiz at deprem.gov.tr
Mon Jun 21 02:21:12 EDT 2004
Michael Barton wrote:
> On Jun 18, 2004, at 10:01 PM, Multiple recipients of list wrote:
>> hello
>> I have newly installed grass57.
>> Firstly I wanted looked at NVIZ
>> Although it worked in grass53, it seemed there was an error in
>> grass57.
> In GRASS 5.7, there is a bug that prevents it from starting from the
> autogenerated dialog box that appears when you type nviz on the
> command line. You can either start nviz from the command line with
> nviz -q (this switch starts nviz without loading any maps at startup)
> or start it from the 'Display/nviz' menu item (which does the same
> thing). Then you can add raster and vector layers to nviz via the
> surface (for rasters), vector (currently supports lines only), and
> sites (for vector points) panels.
> Michael Barton
>> here is the error:
>> Adding panels from
>> /usr/local/grass5.7.cvs-i686-pc-linux-gnu-15_06_2004/etc/nviz2.2/
>> scripts
>> Nv_(panels)
>> toplevel made
>> child killed: segmentation violation
>> while executing
>> "exec
>> NVWISH2.2 -f /usr/local/grass5.7.cvs-i686-pc-
>> linux-gnu-15_06_2004/etc/nviz2.2/sc..."
>> ("eval" body line 1)
>> invoked from within
>> "eval exec $env(GISBASE)/etc/nviz2.2/NVWISH2.2 -f
>> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script $argv -name
>> NVIZ >&@stdout"
>> invoked from within
>> "if {$argv == ""} {
>> #no arguments
>> $env(GISBASE)/etc/nviz2.2/scripts/nviz2.2_script -name NVIZ
>> >&@stdo ..."
>> (file
>> "/usr/local/grass5.7.cvs-i686-pc-linux-gnu-15_06_2004/bin/nviz" line
>> 16)
>> does anyone tell me why ?
>> kind regards
>> Ahmet Temiz
> _____________________________
> C. Michael Barton, Professor & Curator
> School of Human Origins, Cultures, & Societies
> Arizona State University
> Tempe, AZ 85287-2402
> WWW - http://www.public.asu.edu/~cmbarton
> Phone: 480-965-6262
> Fax: 480-965-7671
thank you for your interest
I tried nviz -q from command line.
The problem still exists in grass57 (binary).
when I tried menu item, nothing has changed.
PS. nviz works in grass53.
kind regards
Ahmet Temiz
TURKEY
______________________________________
Inflex - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster at deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
