[GRASSLIST:3729] v.out.shape
ivan marchesini
marchesini at unipg.it
Mon Jun 21 08:35:13 EDT 2004
Dear users...
I'm using v.out.shape to export vector area file...
I write this command:
v.out.shape map=10aspect_5sm_20tn_0.5dmin_10m_neigh9_reclass__1
type=area
but after a short work the program gives me a segmentation fault error:
____________________________________________________
Vertex 49634: 1119880.000000 4337245.000000
Vertex 49635: 1119875.000000 4337250.000000
Vertex 49636: 1119875.000000 4337250.000000
Vertex 49637: 1119870.000000 4337255.000000
Segmentation fault
I have ran v.support to build topology (the vector map was obtained by
r.poly) ant it worked without problems!!!!
If I reduce the area to export from r.poly and I obtain another vector
map, the segmentation fault error occurs at another vertex.....
can you give me some suggestion???
thank you very much
Ivan Marchesini
