[GRASSLIST:3742] Re: compiling grass-5.7.0 on suse 9.0
Glynn Clements
glynn.clements at virgin.net
Thu Jun 24 09:33:08 EDT 2004
Sabine Grabner wrote:
> while compiling grass from source i run into the following problem. any help
> would be appreciated. thank you, sabine
> what i had to manipulate to make it till here:
> /usr/local/grass-5.7.0/include/Make # cp Platform.make.in Platform.make
> /usr/local/grass-5.7.0/include/Make # cp Grass.make.in Grass.make
> because those files are required by Makefile.
Platform.make and Grass.make are generated from Platform.make.in and
Grass.make.in by the configure script. Copying them won't work.
You need to run the configure script.
Glynn Clements <glynn.clements at virgin.net>
