[GRASSLIST:2803] Re: Problem with v.in.db
Radim Blazek
blazek at itc.it
Tue Mar 2 10:10:54 EST 2004
On Friday 27 February 2004 15:58, Leonardo Lami wrote:
> I'd like to import a vector form a database (Postgre SQL), I used the
> command string:
> v.in.db driver=pg
> database=host=server.ufficio.net,dbname=renato,user=ekoclub
> table=anfibi_count x=latitud y=longitud key=count output=anfibi
> The output message say:
> D2/3: SQL: select count, latitud, longitud from anfibi_c_05000_count_tab
> D3/3: describe_table()
> D3/3: kcols = 0
> D3/3: col: count, kcols 0, pgtype : 0, sqltype 0, fsize : 0
> WARNING: pg driver: column 'count', type 0 is not supported
> D3/3: col: latitud, kcols 0, pgtype : 0, sqltype 0, fsize : 0
> WARNING: pg driver: column 'latitud', type 0 is not supported
> D3/3: col: longitud, kcols 0, pgtype : 0, sqltype 0, fsize : 0
> WARNING: pg driver: column 'longitud', type 0 is not supported
> D3/3: row = 0 nrows = 74
> D3/3: Row fetched
> The type specified is the type of the field in the tables?
> I setted it as "int8" and there aren't any 0 value in the fields.
> What's the problem?
> Thank you of all
> Leonardo Lami
Do you have recent version?
Tue Feb 10 14:21:17 2004 I changed pg driver, see
http://grass.itc.it/pipermail/grass5/2004-February/013639.html
Radim
