[GRASSLIST:2985] Re: NViz: command not found
    Markus Neteler
    neteler at itc.it
    Fri Mar 19 05:14:35 EST 2004
On Fri, Mar 19, 2004 at 08:05:31AM +0000, Glynn Clements wrote:
> Richard Greenwood wrote:
> > >                I have a problem -  occuring on the Windows port of GRASS
> > > (5.0.2) using the cygwin
> > > environment and XWindows driver. When I type nviz at the command prompt I
> > > get a "command not found" message.
> > > Searching my cygwin tree I see I only have one file called nviz, in
> > > usr/local/grass5/tcktkgrass/module, and it's only 1K.
> > > Does this mean I haven't installed nviz? If not how do I? Is it possible
> > > to install binaries only, or is compilation of source necessary?
> > You can download a binary distribution of Grass 5.0.3 for Cygwin XServer
> > which has a working Nviz from www.greenwoodmap.com/grass. In my
> > experience, Nviz does not work very in the "generic" or non-XWindows
> > environment.
> Does the wingrass_xserver package (on grass.itc.it and mirrors) not
> include NVIZ?
> The NVWISH2.2 binary is available separately at:
> http://grass.itc.it/grass5/binary/windows_cygnus/wingrass_xserver/NVWISH2.2.bz2
> but that is of no use without the rest of NVIZ.
> I've uploaded a package containing the other components of NVIZ (i.e.
> the Tcl scripts and the bitmaps) to ftp://grass.itc.it/incoming;
> hopefully that can be made available alongside the NVWISH2.2 binary
> (although the package isn't Cygwin-specific, I think that Cygwin is
> the only platform where NVIZ isn't included).
Yes, the file is available now at
Markus
