[GRASSLIST:3021] Fw: Re: grass57 arm deb error
Luis E Menoyo
lemenoyo at usgs.gov
Tue Mar 23 15:42:34 EST 2004
Thanks Stephan, Markus. That solved the problem.
Now I got Grass 5.7 running with Tk/Tcl on the Zaurus. :)
What needs to be done to place Grass 5.7 ARM .deb on the Debian feed? The
Tk/Tcl and GDAL libraries are readily available on the feeds, which, by
using apt-get, saved me from going thru dependency hell during the
install. It would be nice to have a recent version of Grass in the Debian
ARM feed so that dependencies can be automaticaly resolved during install.
Thanks again,
Luis.
Markus Neteler <neteler at itc.it>
Sent by: owner-GRASSLIST at baylor.edu
03/23/04 07:34 AM
To: GRASSLIST at baylor.edu
cc:
Subject: [GRASSLIST:3017] Re: grass57 arm deb error
On Mon, Mar 22, 2004 at 02:24:07PM -0600, rigpa108 at verizon.net wrote:
> I'm getting the following error when invoking grass57
(grass-bin_5.7.0-1_arm.deb) on a Zaurus 5500 running Debian:
> ~/# grass57
> /usr/bin/grass57: line 29:
/mnt/hda6/grass57src/grass-5.7.0/debian/tmp/usr/grass57/etc/Init.sh: No
such file or directory
> /usr/bin/grass57: line 29: exec:
cannor execute: No such file or directory
You have to manually fix the install directory or add a link:
check
/usr/bin/grass57/etc/Init.sh
or
/usr/bin/grass57
if the path points to the correct directory (above indicates that it
doesn't). Yes, a bug in the package.
Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040323/5e9f0ae2/attachment.html
