[GRASSLIST:3057] Re: Compiling 5.3 (2004/03/27) on a ix86/Suse8.2 - part IIIb
    SWlab
    swlab at cornell.edu
    Tue Mar 30 07:17:17 EST 2004
[Tuesday 30 March 2004 06:20] From Paul Kelly
> I searched for
> /usr/include/unctrl.h:57: parse error before "unctrl"
> on google and found quite a few references, several of which suggest
> that the solution may be to delete or rename the file
> /usr/local/lib/gcc-lib/i686-pc-linux-gnu/3.2.2/include/curses.h
Thanks a lot !
Renaming .../curses.h as dummy did the trick. The compilation went without
further problems, apart from a NVIZ2. problem. Seems that I have to check the
configuration of this box...
make[2]: Entering directory
`/home2/sources/grass53_exp_2004_03_27/src.contrib/GMSL/NVIZ2.2/src'
gcc -I/home2/sources/grass53_exp_2004_03_27/src/include -g -O2
-I/usr/X11R6/include   -I/home2/sources/grass53_exp_2004_03_27/src/libes/ogsf
-D_NO_PROTO -D__STDC__   -I/usr/local/pgsql/include   -c nvizAppInit.c -o
OBJ.i686-pc-linux-gnu/nvizAppInit.o
<command line>:1:1: warning: "__STDC__" redefined
<built-in>:9:1: warning: this is the location of the previous definition
In file included from nvizAppInit.c:9:
interface.h:264: conflicting types for `Tk_SetAppName'
/usr/local/include/tkDecls.h:568: previous declaration of `Tk_SetAppName'
make[2]: *** [OBJ.i686-pc-linux-gnu/nvizAppInit.o] Error 1
make[2]: Leaving directory
make[1]: *** [nvwish] Error 2
make[1]: Leaving directory
`/home2/sources/grass53_exp_2004_03_27/src.contrib/GMSL/NVIZ2.2'
GISGEN failure at STEP: src.contrib/GMSL/NVIZ2.2
Thanks again
P.
Soil & Water Laboratory
Dept. of Biological & Environmental Engineering
Cornell University
ITHACA, NY 14853
Tel: (607)255.2463
