[GRASSLIST:3345] Re: Correcting SRTM with MrSID images
tatel at euskalnet.net
Tue May 4 10:49:33 EDT 2004
----- Jatorrizko Mezua -----
Norengandik: "Bryan K. Wright" <bryan at ayesha.phys.Virginia.EDU>
Data: Astelehena, Maiatza 3, 2004 4:29 pm
Gaia: [GRASSLIST:3334] Re: Correcting SRTM with MrSID images
> Hi folks,
> tatel at euskalnet.net said:
> > Unfortunatelly I can't register SRTM and image data. After
> > reprojecting image from UTM-WGS84 to Lat_Lon-WGS84, it seems to
> be a
> > shift of about 250-300 meters towards W in SRTM from image. More
> > confusingly, this
> I've also seen a shift of about 200 meters between MrSid-format
> DOQQs and the corresponding USGS DRG files. The MrSid files were
> decodedusing the Windows version of mrsiddecode, which produces a
> tiff and a
> tfw file. There were actually two oddities in the tfw files. Here's
> a quote from an earlier message I posted to the list about this
> problem:
> bryan at ayesha.phys.Virginia.EDU said:
> > Two oddities with the tfw files, though: the fourth line of the
> file> (cell size) ended up being a positive number, which r.in.tiff
> didn't
> > like. Adding a minus sign fixed the problem. I also found that the
> > last line of the file (northing) was offset by 200 meters
> relative to
> > the USGS topo maps I'm using. These may just be problems with the
> > original sid/sdw files I happened to be using.
> Since then I've heard from a couple of other people who've
> noticed the same thing.
> Bryan
> Bryan Wright |"If you take cranberries and stew them
> like
> Physics Department | applesauce, they taste much more like
> prunes
> University of Virginia | than rhubarb does." -- Groucho
> Charlottesville, VA 22901 |
> (434) 924-7218 | bryan at virginia.edu
