[GRASSLIST:3444] Re: new 53 osx compile
Glynn Clements
glynn.clements at virgin.net
Wed May 19 19:05:50 EDT 2004
Kirk R. Wythers wrote:
> Thanks for the tip... I think... It looks like a mess:
> main.c:78: error: parse error before "library"
> main.c:79: error: parse error before "face"
> main.c:81: error: parse error before "face"
> main.c:83: error: parse error before '*' token
> main.c:84: error: parse error before "FT_Face"
> main.c:86: error: parse error before "FT_Face"
Most likely, <freetype/freetype.h> is from FreeType version 1.
d.text.freetype requires FreeType 2.
If you have FreeType 2, you may need to use --with-freetype-includes=
to specify the location of its headers. Although that may not be
sufficient if FreeType 1 is in one of the include directories which
are explicitly listed (/usr/X11R6/include or /sw/include).
Glynn Clements <glynn.clements at virgin.net>
