[GRASSLIST:3450] writing ascii files from two different raster maps
    Jaime Carrera
    jaicarrerahdez at yahoo.com
    Thu May 20 10:52:22 EDT 2004
Hi all,
I'm trying to write a module in order to write an ascii file from two or more different raster files. Can I use two different options or should I use the multiple = YES option in G_define_option(). To clarify my question I have the following examples:
CASE 1:
inputone=G_define_option()
inputone-> key            ="firstinput";
inputone-> type           =TYPE_STRING;
inputone->required       =YES;
inputone->gisprompt    = "old, cell,raster";
inputone->description   ="Name of input layer no 1";
inputtwo=G_define_option()
inputtwo-> key            ="secondinput";
inputtwo-> type           =TYPE_STRING;
inputtwo->required       =YES;
inputtwo->gisprompt    = "old, cell,raster";
inputtwo->description   ="Name of input layer no 2";
CASE 2:
input =G_define_option()
input-> key            ="firstinput";
input -> type           =TYPE_STRING;
input->required       =YES;
input->multiple       =YES;
input ->gisprompt    = "old, cell,raster";
input->description   ="Name of input layer";
In case I need to use the second case, how can I control the way in which the ascii file is written (I need to write in the ASCII file other parameters between each raster layer).
Thanks,
Jaime
Do You Yahoo!?
Todo lo que quieres saber de Estados Unidos, América Latina y el resto del Mundo.
Visíta Yahoo! Noticias.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20040520/7246585f/attachment.html
