[GRASSLIST:3521] Re: script for importing Terra-ASTER data
Michael Barton
michael.barton at asu.edu
Thu May 27 21:58:03 EDT 2004
The script should work in either 5.3 or 5.7, but the GUI interface only
comes up in 5.7.
I am using ASTER L1B.I can't remember for sure, but I think you need
Level 1B to get the GCP's (ground control points) needed for
georeferencing. Of course you need L1A to ID GCP's to send to the ASTER
folks if you want them to make a DEM.
Michael
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
On May 27, 2004, at 2:40 AM, Zbigniew Perski wrote:
> Hi,
> The script is working now. I have solved also the problem before using
> dos2unix (following Paul Kelly suggestion). Unfortunately I can not
> enjoy it in this moment because I have grass5.0.3. I am planning to
> start in the next days with 5.7 so I will test it.
> I have another question: which kind of ASTER processing level could be
> read by your script? I mean, the scenes which I have are Level 1A.
> Many thanks
> Zbigniew
