[GRASSLIST:4757] Re: create raster from series of rasters...
Hamish
hamish_nospam at yahoo.com
Tue Nov 9 18:34:41 EST 2004
> I have a series of 364 raster images, and I would like to create a
> single raster, where each cell is a function of a series of 364 other
> rasters.
> I have tried r.series, but it seems to die after 211 images...
> I have been able to get a result with only half of my data, but it
> would be nice to incorporate all 364 rasters in the final calculation.
> Any ideas?
You need to edit lib/gis/G.h and change MAXFILES to something like 450
then recompile GRASS.
raster/r.patch/nfiles.h notes:
* Must be smaller than MAXFILES as defined in src/libes/gis/G.h which
* in turn must be smaller than the operating system's limit.
* (Given by `cat /proc/sys/fs/file-max` in Linux 2.4)
It should be ok, but having a huge amount of maps open at once may tax
your system resources somewhat..
bonus hint: use input=`g.mlist sep=, pattern='*.map'` to make the
r.series command a bit easier to set up.
I guess we should put in a check on # of input files and generate a
warning.. r.series, r.patch, others? r.out.mpeg should be ok.
Hamish
