[GRASSLIST:4779] Re: v.in.ogr gives dbmi: db_open_database() not implemented
Huidae Cho
grass4u at gmail.com
Thu Nov 11 12:17:16 EST 2004
New code lives in grass51 CVS HEAD.
On Thu, 11 Nov 2004 11:16:07 -0600, Huidae Cho <grass4u at gmail.com> wrote:
> Hi,
> I fixed it and shared libraries work on Cygwin, so could you test this
> on MacOS? Db drivers with shared libraries should work; you don't need
> --disable-shared flag.
> Thanks,
> Huidae Cho
> On Mon, 8 Nov 2004 21:25:20 -0800 (PST), mahoneyd at unbc.ca
> <mahoneyd at unbc.ca> wrote:
> > Thanks, that fixed it. Does anyone know why shared libraries no longer
> > work? They were fine before I reinstalled Mac OS (and updated the grass
> > sources from CVS).
> > Dave
> > > Hi,
> > > We have the same problem on Cygwin in terms of the db error. You may
> > > want to configure with --disable-shared.
> > > ./configure --disable-shared
> > > make
> > > Hope this helps.
> > > Huidae Cho
> > > On Sun, 07 Nov 2004 19:08:13 -0800, David Mahoney <mahoneyd at unbc.ca>
> > > wrote:
> > >> Hi,
> > >> I am running Mac OS X (10.2.8) and have compiled grass 5.7 (cvs).
> > >> However, when I run v.in.ogr, I get this error
> > >> GRASS 5.7.cvs:~/gisdata/grass_x/93f/93f037 > v.in.ogr dsn=tctr_037 \
> > >> layer=LAB,ARC type=line out=tctr_037
> > >> A datum name nad83 (North_American_Datum_1983) was specified without
> > >> transformation parameters.
> > >> WARNING: Non-interactive mode: the GRASS default for nad83 is
> > >> towgs84=0.000,0.000,0.000.
> > >> Projection of input dataset and current location appear to match.
> > >> Proceeding with import...
> > >> WARNING: The vector 'tctr_037' already exists and will be overwritten.
> > >> WARNING: Cannot open database
> > >> '/Users/dave/gisdata/grass/trim-utm10/dave/dbf'
> > >> '/Users/dave/gisdata/grass/trim-utm10/dave/dbf' by driver
> > >> 'dbf'
> > >> WARNING: Cannot get info if table 'tctr_037_1' linked to vector exists.
> > >> ERROR: Cannot delete existing vector tctr_037
> > >> Is this a GDAL problem?
> > >> Thanks,
> > >> Dave
