[GRASSLIST:4782] trouble with v.proj
    bfdi533
    bfdi533 at cbacc-security3.bus.utexas.edu
    Thu Nov 11 15:01:22 EST 2004
I have a TIGER line file that was imported into a LL location with an
output from g.projinfo here:
PROJ_INFO file:
datum:   wgs84
dx:      0.000000
dy:      0.000000
dz:      0.000000
proj:    ll
ellps:   wgs84
PROJ_UNITS file:
unit:    degree
units:   degrees
meters:  1.0
I then input another roads file into a location in TX State Plane format
with output from g.projinfo here:
PROJ_INFO file:
proj:    lcc
a:       0.63782064e+07
es:      0.6768657997291094e-02
x_0:     0.6096012192024384e+06
y_0:     0
lon_0:   100d20'w
lat_0:   29d40'n
lat_1:   31d53'n
lat_2:   30d7'n
PROJ_UNITS file:
unit:    meter
units:   meters
meters:  1.0
I then tried v.proj from the LL location INTO the State Plane location
and did a d.vect on both sets of roads.  They do not line up.
Here is the region from the STP imported vector file:
GRASS:~ > g.region vect=streetcl
GRASS:~ > d.erase
GRASS:~ > g.region -l
long: 48.34520 lat: 86.33708 (north/west corner)
long: 51.00098 lat: 85.50330 (north/east corner)
long: 41.70189 lat: 85.31135 (south/east corner)
long: 38.11301 lat: 86.14387 (south/west corner)
rows:       512
cols:       514
Center Longitude: 44:47:24.969634E [44.79027]
Center latitude:  85:49:26.046164N [85.82390]
And here is the region that I get from running the same commands on the
vector file that was imported with v.proj:
GRASS:~ > g.region vect=tx_travis
GRASS:~ > d.erase
long: -98.17640 lat: 30.64542 (north/west corner)
long: -97.35039 lat: 30.62892 (north/east corner)
long: -97.36951 lat: 30.00828 (south/east corner)
long: -98.19023 lat: 30.02468 (south/west corner)
rows:       150
cols:       147
Center Longitude: 97:46:17.870455W [-97.77163]
Center latitude:  30:19:36.571973N [30.32683]
It seems quite likely that I have something wrong with the STP location
but I have recreated it more than once using the right info and then
imported data (arcinfo shape files) that say they are in the STP coords
that I created.  But, the above just does not line up right and the
coords look to be correct for the projected vector file, actually.
Any ideas on what I am doing wrong?
Ed
