[GRASSLIST:4793] v.digit crash
"Molina Müller"
yuhuu at gmx.de
Thu Nov 11 18:07:56 EST 2004
Could anybody give me an idea what's wrong with my v.digit? (grass57,
Cygwin, WinNT4, NTFS)
Neither installing the downloadable cygwin binaries nor compiling grass57
myself gives me a usable v.digit.
Both versions do the same:
-erase mon
-execute bgcmd
-display the nodes already present in the map
and finally:
-Segmentation fault (Core dumped) (if started on the command line)
-nothing (if started by the tcltk-menu)
-Error: child killed: segmentation violation (if started by the display
manager); complete error message see below.
Before v.digit dies the harddisc is quite busy for about 1/4 sec.
With DEBUG=3 the last message on the console is:
D2/3: node = 31 NodeSymb = 13
Segmentation fault (core dumped)
(BTW: The vector map contains 31 nodes)
I'd very appreciate an idea what to do. I've already read the thread
http://grass.itc.it/pipermail/grass5/2003-April/007754.html, but I don't
understand what that could mean for me.
Starting grass with grass57 -text doesn't help.
I'd be really glad to get this great program working!!
Molina
Error Message when v.digit started by display manager:
while executing
"exec v.digit -n map=railr >@stdout 2>@stdout"
("eval" body line 1)
invoked from within
"eval "exec $cmd >@stdout 2>@stdout""
(procedure "Dm::execute" line 12)
invoked from within
"Dm::execute $cmd"
(procedure "DmVector::WorkOnVector" line 21)
invoked from within
"DmVector::WorkOnVector $sel"
("vector" arm line 2)
invoked from within
"switch $type {
raster {
return
labels {
return
vector {
DmVector::WorkOnVecto..."
(procedure "Dm::edit" line 14)
invoked from within
"Dm::edit"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .mainframe.topf.tb0.bbox2.b5"
(command bound to event)
Geschenkt: 3 Monate GMX ProMail + 3 Top-Spielfilme auf DVD
++ Jetzt kostenlos testen http://www.gmx.net/de/go/mail ++
