[GRASSLIST:4826] Problems importing Data into lat/lon with negtiv south value
Stephan Holl
sholl at gmx.net
Sun Nov 14 04:27:59 EST 2004
Dear Users,
I am trying to import some MODIS data into GRASS. In a first step I
managed to convert a subdataset of the MODIS data into img-format using
gdal_translate.
The dataset is a global dataset which should be in lat/long.
gdal_translate HDF4_SDS:EOS_GRID:"modis.hdf":2 -of HFA test_hdf.img
Input file size is 3600, 1800
0...10...20...30...40...50...60...70...80...90...100 - done.
steph at bim:~/modis > gdalinfo test_hdf.img
Driver: HFA/Erdas Imagine Images (.img)
Size is 3600, 1800
Coordinate System is `'
Origin = (0.000000,0.000000)
Pixel Size = (1.00000000,1.00000000)
Metadata:
HDFEOSVersion=HDFEOS_V2.4
LOCALGRANULEID=MOD08D3H.A2003090.004.2003093014745.hdf
PRODUCTIONDATETIME=2003-04-03T01:47:45.000Z
DAYNIGHTFLAG=Both
REPROCESSINGACTUAL=processed once
LOCALVERSIONID=004
REPROCESSINGPLANNED=further update is anticipated
VERSIONID=4
SHORTNAME=MOD08D3H
INPUTPOINTER=MOD04_L2.A2003090.0250.004.2003092034313.hdf,
[more metadata skipped]
EASTBOUNDINGCOORDINATE=180.000000
WESTBOUNDINGCOORDINATE=-180.000000 SOUTHBOUNDINGCOORDINATE=-90.000000
NORTHBOUNDINGCOORDINATE=90.000000
RANGEENDINGDATE=2003-04-01
RANGEENDINGTIME=00:00:00
RANGEBEGINNINGDATE=2003-03-31
RANGEBEGINNINGTIME=00:00:00
PGEVERSION=4.0.3
ASSOCIATEDSENSORSHORTNAME=MODIS
ASSOCIATEDPLATFORMSHORTNAME=Terra
ASSOCIATEDINSTRUMENTSHORTNAME=MODIS
PROCESSINGENVIRONMENT=Linux minion425 2.4.18-27.7.xsmp #1 SMP Fri Mar
14 05:52:30 EST 2003 i686 unknown
LOCALINPUTGRANULEID=MOD04_L2.A2003090.0250.004.2003092034313.hdf,
LONGNAME=MODIS/Terra Aerosol Cloud Water Vapor Ozone Daily L3 Global
0.1 Deg CMG valid_range=0, 18000
_FillValue=-9999
long_name=Sensor Zenith Angle (Cell to Sensor): Mean
units=Degrees
scale_factor=0.01
add_offset=0
Level_2_Pixel_Values_Read_As=Real
Derived_From_Level_2_Data_Set=Sensor_Zenith
Included_Level_2_Nighttime_Data=False
Quality_Assurance_Data_Set=None
Statistic_Type=Simple
Aggregation_Data_Set=None
Corner Coordinates:
Upper Left ( 0.0000000, 0.0000000)
Lower Left ( 0.000, 1800.000)
Upper Right ( 3600.000, 0.000)
Lower Right ( 3600.000, 1800.000)
Center ( 1800.000, 900.000)
Band 1 Block=64x64 Type=Int16, ColorInterp=Undefined
The problem seems to be with negative south and west values, as GRASS
needs south boundaries as 90S and not -90 (as my data have).
Is there a solution to use this kind of data in GRASS? Thanks for any
pointers on this topic.
Kind Regards
Stephan Holl
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20041114/ee32ec86/attachment.bin
