[GRASSLIST:4910] Re: libogdi31.so
    Markus Neteler
    neteler at itc.it
    Tue Nov 23 05:38:06 EST 2004
On Tue, Nov 23, 2004 at 10:30:37AM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > Do you refer to the 'grass.itc.it' binaries?
> > Since they are linked against dynamic GDAL libs I don't see the
> > problem (as I am not aware of distributing GDAL on 'grass.itc.it').
> FWIW, the 5.3 documents/release_rules.txt file still says:
>    o For r.in.gdal we need "libgdal" which has to be included into the GRASS
>      binary package. Finally store "libgdal.1.1.so" in $GISBASE/lib/
Yes, but he was refering to GRASS 5.7.
In a personal communication it turned out to be a local problem
as also netcdf, jasper etc was used which are not even installed
on grass.itc.it.
Markus
