[GRASSLIST:4915] Re: rasters reprojection UTM -> LAEA
Rado Bonk
rado.bonk at jrc.it
Tue Nov 23 09:13:38 EST 2004
Dear GRASS users,
I used following steps:
TARGET LOCATIOON (UTM) DEFINED based on the following info from data
provider:
"ETRS89, UTM-Abbildung, Zone 33; DHHN 92, BKG Geoid"
LOCATION PROJ_INFO is:
proj: utm
ellps: grs80
a: 6378137.0000000000
es: 0.0066943800
f: 298.2572221010
zone: 33
GRASS:~> r.in.gdal input=3753no output=375
ERROR: Projection of dataset does not appear to match current location.
proj: utm
ellps: grs80
es: 0.0066943800
f: 298.2572221010
zone: 33
cellhd.proj = 0 (unreferenced)
You can use the -o flag to r.in.gdal to override this check and use the
location definition for the dataset.
Consider to generate a new location with 'location' parameter from input
data set.
GRASS:~> r.in.gdal -o input=3753no output=3753 location=3753
g.projinfo gives no results since PROJ_INFO and PROJ_UNITS do not exists
GRASS:~> g.setproj:
XY-location cannot be projected.
GRASS:~ > g.region -p
projection: 0 (x,y)
zone: 0
north: 5791542.5
south: 5788747.5
west: 3471422.5
east: 3477112.5
nsres: 5
ewres: 5
rows: 559
cols: 1138
Basically:
- I can't define projection for 3753 LOCATION using g.setproj
- I can't reproject raster since r.proj can not reproject XY location
If I defined TARGET LOCATION worng, why r.in.gdal did not produced
correct location with "-o" parameter (???), but produced XY location
only?
Thanks for the ideas,
Rado Bonk
Radoslav Bonk
European Commission - DG Joint Research Centre (JRC)
Institute of Environment and Sustainability (IES)
LM Unit - Natural Hazards
Via E. Fermi, TP 261, 210 20 Ispra (VA), ITALY
tel: 0039 0332 78 6013
fax: 0039 0332 78 6653
http://natural-hazards.jrc.it/floods
On Nov 23, 2004, at 9:35 AM, Markus Neteler wrote:
> On Mon, Nov 22, 2004 at 01:08:19PM +0100, Rado Bonk wrote:
>> Dear GRASS users,
>> I have problems with reprojecting ArcINFO rasters from UTM to LAEA. I
>> defined LOCATION to imported the rasters (based on data provider
>> info):
>> proj: utm
>> ellps: grs80
>> es: 0.0066943800
>> f: 298.2572221010
>> zone: 33
>> However, r.in.gdal did not import the rasters in this location, and
> please post the error message to better understand the problem.
> Markus
