[GRASSLIST:4928] Identifying (or removing) island polygons
David Mahoney
mahoneyd at unbc.ca
Tue Nov 23 21:05:48 EST 2004
I am trying to build spaghetti data in GRASS 5.7. The input data is lines
with attributes, and I want to end with polygons. I have managed to build
the lines to polygons and use v.distance to attach the attributes of the
nearest lines to the centroids in the polygon layer. However, there does
not seem to be a convenient way to remove/reclass the island polygons. I
do not want the islands to have the attributes of the surrounding lines,
rather they are holes in the polygon layer. I can use some procedure where
I run every attribute class against every other class in v.select to
determine the wholly enclosed polygons, but I was hoping for a more
elegant solution. Any thoughts?
Island polygons ID might be a nice option for v.to.db or v.clean, yes?
Dave
