[GRASSLIST:4933] Re: v.database
    Leonardo Lami
    lami at faunalia.it
    Wed Nov 24 06:50:02 EST 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> It is maybe too confusing to have separate default driver/database for
> db.* and v.* modules. First I thought, that in some cases
> it could be useful, but usually both groups of modules use the same
> database. Driver/database options can be used if necessary (v.in.db).
> What do you think, should we remove v.database and use db.connect
> settings also for vectors?
> Radim
I think there is no problem if you remove v.database.
I do not remember if you resolved the problem about v.db.connect and schema.
I think that there is problem to connect a vector with a table in a schema
with v.db.connect.
> db.login was added to 5.7. It can be used to set user and password
> for driver/database.
> WARNING: password is stored as text in $HOME/.grasslogin5
> User and password from database definition (db.connect,v.db.connect) is
> no more used.
> This change was necessary to allow work in groups. Now it is possible
> to give only select privileges to group or others. Typicaly
> location   -> database
> mapset     -> schema
> UNIX user  -> database user
> UNIX group -> database group
> Then user can grant select on schema to group and public.
> Administrators should keep in sync database and UNIX users,
> especially don't forget to remove database user if UNIX user
> is removed.
> If you revoke access to group or others using g.access,
> you should also revoke privileges on related database schema.
I'am agree.
I'd like to know if is it possible to allow that more users work on the same
mapset?
The contemporary access can be avoid by a lock.
Thanks
Leonardo Lami
lami at faunalia.it            www.faunalia.it
Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy   Tel: (+39)349-1310164
GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
https://www.biglumber.com
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBpHVq92hCyP73w7ARAtd4AKCAsI0KIqPJdyMTycHcPmclfcCYdQCeOjd1
cXeNkqpeYizclo5hRyrc7lo=
=lz+S
-----END PGP SIGNATURE-----
