[GRASSLIST:4950] Re: v.database
Leonardo Lami
lami at faunalia.it
Thu Nov 25 04:06:48 EST 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Alle 17:39, mercoledì 24 novembre 2004, hai scritto:
> Leonardo Lami wrote:
> > I think there is no problem if you remove v.database.
> > I do not remember if you resolved the problem about v.db.connect and
> > schema. I think that there is problem to connect a vector with a table in
> > a schema with v.db.connect.
> Cannot you simply use table=myschema.mytable ?
> Radim
Hi Radim,
If I use this option with v.database or db.connect I have no problem but if I
use it with v.db.connect I have this ouutput message:
v.db.connect map=sir_clump driver=pg
database=host=192.168.0.10,dbname=faunalia,user=username,password=######
table=prova.anfibi key=cat field=1
ERROR: Table <prova.anfibi> does not exist in database
<host=192.168.0.10,dbname=faunalia,user=username,password=######>
Thanks
Ciao
Leo
Leonardo Lami
lami at faunalia.it www.faunalia.it
Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy Tel: (+39)349-1310164
GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
https://www.biglumber.com
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBpaCt92hCyP73w7ARAn+bAJ4g3RTP55CSwwYszr7mOPGX//1cTQCZAUF8
qUYnr/oVvR2ke9pAdIjTDEA=
=IvlZ
-----END PGP SIGNATURE-----
