[GRASSLIST:4964] Re: v.database
Radim Blazek
blazek at itc.it
Thu Nov 25 11:05:12 EST 2004
I have removed v.database. Vector modules will use
default values set by db.connect.
db.tables returns schema.table if chemas are available.
You can use v.db.connect table=schema.table
Default schema can be set by db.connect.
WARNING: default schema is used by all db.* modules.
All this works with Postgres only.
Radim
Leonardo Lami wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
>>It is maybe too confusing to have separate default driver/database for
>>db.* and v.* modules. First I thought, that in some cases
>>it could be useful, but usually both groups of modules use the same
>>database. Driver/database options can be used if necessary (v.in.db).
>>What do you think, should we remove v.database and use db.connect
>>settings also for vectors?
>>Radim
> I think there is no problem if you remove v.database.
> I do not remember if you resolved the problem about v.db.connect and schema.
> I think that there is problem to connect a vector with a table in a schema
> with v.db.connect.
>>db.login was added to 5.7. It can be used to set user and password
>>for driver/database.
>>WARNING: password is stored as text in $HOME/.grasslogin5
>>User and password from database definition (db.connect,v.db.connect) is
>>no more used.
>>This change was necessary to allow work in groups. Now it is possible
>>to give only select privileges to group or others. Typicaly
>>location -> database
>>mapset -> schema
>>UNIX user -> database user
>>UNIX group -> database group
>>Then user can grant select on schema to group and public.
>>Administrators should keep in sync database and UNIX users,
>>especially don't forget to remove database user if UNIX user
>>is removed.
>>If you revoke access to group or others using g.access,
>>you should also revoke privileges on related database schema.
> I'am agree.
> I'd like to know if is it possible to allow that more users work on the same
> mapset?
> The contemporary access can be avoid by a lock.
> Thanks
> Leonardo Lami
> lami at faunalia.it www.faunalia.it
> Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy Tel: (+39)349-1310164
> GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
> https://www.biglumber.com
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.4 (GNU/Linux)
> iD8DBQFBpHVq92hCyP73w7ARAtd4AKCAsI0KIqPJdyMTycHcPmclfcCYdQCeOjd1
> cXeNkqpeYizclo5hRyrc7lo=
> =lz+S
> -----END PGP SIGNATURE-----
