[GRASSLIST:4969] Re: grass 5.7 vs. Debian sid
Stephan Holl
sholl at gmx.net
Fri Nov 26 02:08:16 EST 2004
Hello Dan,
On Fri, 26 Nov 2004 07:57:26 +0800 Dan Jacobson <jidanni at jidanni.org>
wrote:
> Odd, 7MB for source on
> http://grass.cis.sinica.edu.tw/grass57/source/snapshot/
> sounds like the 7MB for binary on
> http://grass.itc.it/grass57/binary/linux/snapshot/
I would recommend downloading the Source-snapshot of GRASS 5.7 which
comes with a proper debian/-folder to build your own .deb on the
debian-way.
source-snapshot:
http://grass.itc.it/grass57/source/snapshot/ (7.2mb)
You can easily update from CVS with this snapshot, so no long downloads
anymore...
Give it a try.
I did that on my (heaviliy modified) debian sid box successfully once.
> and not the several times larger file one sees with
> apt-get source grass --print-uris
> Hmmm, how did it get so slim and trim?
> Well if I Use The Source, then I would have been immune from the above
> problems in the first place?
Hope that helps.
Cheers
Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20041126/94a4b5d4/attachment.bin
