[GRASSLIST:4975] Re: .mxt
Damiano G. Preatoni
prea at uninsubria.it
Fri Nov 26 10:17:44 EST 2004
On Friday 26 November 2004 02:49 pm, Michail Pantelelis wrote:
> ivan marchesini wrote:
> >hi to all...
> >do someone know the .mxt extension what is about???
> >they gave me some files in this format and I don't know what I have to
> >do with them....!!!!
An .mxt file is an ESRI ArcGIS template file, it works like a M$ Word ".dot"
file.
Usually, the .mxt file itself is _useless_ since it is used (when it works) to
define a base layout (e.g. paper size, map frame position, legend position,
presentation coverages and so on) for bulk map procuction in series.
Of course, the .mxt, once opened, will generate a new document, and probably
it will serach for some shapefile or coverage or grid or imagery...
HTH!
Damiano G. Preatoni, PhD
Unità di Analisi e Gestione delle Risorse Ambientali
Dipartimento "Ambiente-Salute-Sicurezza"
Università degli Studi dell'Insubria
Via J.H. Dunant, 3 - 21100 Varese (ITALY)
http://biocenosi.dipbsf.uninsubria.it/
ICQ: 78690321
Odigo: 2645129
