[GRASSLIST:4983] Re: grass 5.7 vs. Debian sid
Dan Jacobson jidanni at jidanni.org
Sat Nov 27 21:36:26 EST 2004
>>>>> "S" == Stephan Holl <sholl at gmx.net> writes:
S> I would recommend downloading the Source-snapshot of GRASS 5.7 which
S> comes with a proper debian/-folder to build your own .deb on the
S> debian-way. http://grass.itc.it/grass57/source/snapshot/ (7.2mb)
Then do dpkg-checkbuilddeps to see the additional packages you will
need to compile it.  They ought to put this where you can see it
before you download. [Took several wget -c's throughout the night just
to find out.]:
Build-Depends: autoconf (>=2.13), autotools-dev, bison | byacc, csh,
debhelper (>= 4.0.2), doxygen, fftw3-dev, flex, libc6-dev,
libfreetype6-dev, libgdal1-dev, libjpeg62-dev | libjpeg-mmx-dev,
libncurses5-dev, libpng12-dev, libreadline4-dev, libtiff4-dev,
postgresql-client, postgresql-dev, proj (>= 4.4.7), tcl8.3-dev,
tk8.3-dev, unixodbc-dev, xlibmesa-gl-dev, xlibmesa-glu-dev, xlibs-dev,
zlib1g-dev, libgdal1
(Note how csh is there and not virtual c-shell, etc.)
I will now try the third alternative,
http://bullhorn.org unstable/main libgrass5.7 5.7.0-4, grass5.7 5.7.0-4
