[GRASSLIST:4984] Re: adding mile markers to curvy roads
Dan Jacobson
jidanni at jidanni.org
Sat Nov 27 22:52:12 EST 2004
Radim> LRS is not less complicated. I have created source code package
Radim> (http://mpa.itc.it/radim/lrs/index.html)
I doesn't look like I will be able to compile grass, having to make
another modem call each dependency I discover. Therefore can someone
make these into something I can use on debian, as there is perhaps a
chance I will be able to use the bullhorn.org .debs.
