[GRASSLIST:5003] Re: QGIS + GRASS problem
Kenlo Nishida
kenlo at sakura.cc.tsukuba.ac.jp
Tue Nov 30 09:58:35 EST 2004
Dear Radim,
Thanks for your advice. It helped.
The RPM of GDAL didn't support GRASS.
I compiled GDAL from the source and then
my QGIS imported GRASS data.
Kenlo Nishida
Radim Blazek wrote:
> Kenlo Nishida wrote:
>> Hi GRASS users,
>> I am trying to use QGIS with GRASS support. All the installation of
>> GDAL, GRASS5.7, and QGIS completed fine and I can invoke QGIS on
>> the GRASS shell. However, when I try to add a GRASS raster layer on
>> QGIS with the GRASS plug-in button, it refuses to do so giving a
>> message which says:
>> (...GRASS raster dataset name...) is not a supported raster data
>> source.
>> Of course, the GRASS raster dataset appears fine on GRASS with d.rast
>> command.
>> The GDAL interface seems working fine both on GRASS and QGIS because a
>> GeoTIFF dataset (Landsat data) could be imported to them.
>> Can anyone kindly give me a crue to fix this problem?
>> PC: Vine-Linux 3.0 on x86
>> GRASS: installed from source (grass-5.7.0.tar.gz)
>> GDAL: gdal-1.2.3-mh2.rpm gdal-devel-1.2.3-mh2
>> QGIS: installed from source (qgis-0.5.0.tar.gz)
> Are you sure that your GDAL is compiled with GRASS support?
> gdalinfo --formats
> Radim
Kenlo Nishida
Institute of Agricultural and Forest Engineering
University of Tsukuba, Japan 305-8572
