[GRASSLIST:4509] multiple field....
    Massimiliano Cannata
    massimiliano.cannata at supsi.ch
    Tue Oct 12 13:39:56 EDT 2004
Hiello everybody,
I'm trying to  write a code to create a point map (in 5.7 version) with
6 field but I have some great doubt.....
I guess I have to create 1 coor file with 6 fields (columns) like this:
point_id | x | y | z | field_1 | field_2 | ....... | field_6
and 6 tables with attributes: one for every field.......
table for field_1:
cat | attribute_1 | attribute_2 | ........ | attribute_n
table for field_2:
etc.....
my question are:
with the following code do I create a field_info struct for the field_1
or with 1 field?
Fi = Vect_default_field_info ( &Map, 1, NULL, GV_1TABLE );
and with the foolowing code do I create the table for field_1 ( cat |
attribute_1 | attribute_2 ) ?
db_zero_string (&sql);
sprintf ( buf, "create table %s ( cat integer", Fi->table );
db_append_string ( &sql, buf );
db_append_string ( &sql, ", attribute_1integer" );
sprintf ( buf, ", attribute_2 varchar(%d)", clen );
db_append_string ( &sql, ")" );
Thanks you for the future response and for any suggestion/help.......
Maxi
_____________________________________________________
Ing. Massimiliano Cannata
SUPSI - Istituto Scienze della Terra
C.P. 72 - CH-6952 Canobbio (Ticino, Switzerland)
Tel +41 (0)91 935 12 25 - Fax +41 (0)91 935 12 09
mailto:massimiliano.cannata at supsi.ch
http://www.ist.supsi.ch
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20041012/7cfff707/attachment.html
