[GRASSLIST:4511] Re: compiling GRASS 5.7.0
Glynn Clements glynn.clements at virgin.net
Tue Oct 12 14:17:31 EDT 2004
Ulrich Leopold wrote:
> Ok I started compiling GRASS 5.7.x from a snapshot version with:
> grass57src_cvs_snapshot_exp_2004_10_09.tar.gz
> and
> grass-5.3.0.tar.gz
> I get now the start up error below.
> The compilation process finished fine.
> uleopold at snowdon:~> /scratch/usr/local/bin/grass57
> cat: /scratch/usr/local/grass-5.7.cvs/etc/grass_intro: No such file or
> directory
> Hit RETURN to continue
> Starting GRASS ...
> Error in startup script: couldn't read file
> "/scratch/usr/local/grass-5.7.cvs/etc/gis_set.tcl": no such file or
> directory
> /scratch/usr/local/grass-5.7.cvs/etc/Init.sh: line 1: g.gisenv: command
> not found
> not found
> not found
> /scratch/usr/local/grass-5.7.cvs/etc/Init.sh: line 526:
> /scratch/usr/local/grass-5.7.cvs/etc/lock: No such file or directory
> Unable to properly access ///.gislock
These all suggest that the compilation didn't actually finish fine.
See the error.log file for the list of modules which failed to compile
(lib/init and general/g.gisenv will probably be among them). See the
output from "make" for the actual error messages.
Glynn Clements <glynn.clements at virgin.net>
