[GRASSLIST:4516] grass and Mapserver
    Ljiljana
    ljiljana at fesb.hr
    Wed Oct 13 05:03:16 EDT 2004
Hi everyone!
I am trying to start grass mapserver demo,  with  spearfish location for some time and i realy don't know what else to do.
I am using :
linux suse 9.0 with apache2 web serever, PHP 4.3.9 configured as CGI,
libgrass5-1.0.0,
gdal 1.2.3 configured with-libgrass
mapserver -4.2.3 configured wit folowing arguments:
./configure  --with-eppl --with-threads --with-proj --with-gdal=/usr/local/bin/gdal-config --with-ogr=/usr/local/bin/gdal-config --with-php=/root/php-4.3.9 --with-gd=/usr/local  --with-freetype=/usr/bin  --with-pdf
I have installed grass57 and i copied .grassrc57 i htdocs directory, but I still recive message
msDrawMap(): Image handling error. Failed to draw layer named 'soils'.
msDrawRaster(): Image handling error. Unrecognized or unsupported image format
drawEPP(): Image handling error. /srv/www/grassdata/spearfish/PERMANENT/cellhd/soils is not an EPPL file.
when I try to display soils layer directly from the grass location.
All other layers are displaying corectly.
I get the folowing outputs for the tests
#./mapserv -v
MapServer version 4.2.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
 # ldd /usr/local/lib/libgdal.so
        libodbc.so.1 => /usr/local/lib/libodbc.so.1 (0x4032c000)
        libxerces-c1_6_0.so => /usr/local/lib/libxerces-c1_6_0.so (0x4038a000)
        libpthread.so.0 => /lib/i686/libpthread.so.0 (0x405b7000)
        libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40609000)
        libpng.so.3 => /usr/lib/libpng.so.3 (0x40629000)
        libgrass5.so.0 => /usr/local/lib/libgrass5.so.0 (0x40657000)
        libz.so.1 => /lib/libz.so.1 (0x406dd000)
        libdl.so.2 => /lib/libdl.so.2 (0x406ec000)
        libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x406ef000)
        libm.so.6 => /lib/i686/libm.so.6 (0x407b0000)
        libc.so.6 => /lib/i686/libc.so.6 (0x407d3000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40906000)
        /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
        libnsl.so.1 => /lib/libnsl.so.1 (0x4090e000)
 # /usr/local/bin/gdal-config --formats
gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem jdem envisat elas fit vrt usgsdem l1b nitf bmp pcidsk bsb gif jpeg png grass
What else could go wrong??
best regards
Ljiljana Bodrozic
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20041013/d7b13b97/attachment.html
