[GRASSLIST:4530] Re: grass and Mapserver
    Ljiljana
    ljiljana at fesb.hr
    Thu Oct 14 02:36:44 EDT 2004
Thanx!!!
I have already tried that, with all other combinations (.grassrc in www ,
grassrc with all permisions in htdocs, , grassrc in database folder...) . I
dont know what is the difference now,  but now it works.
Now  I will be afraid to change anything :)
Thank you once again
Ljiljana Bodrozic
----- Original Message -----
From: "Richard Greenwood" <richard.greenwood at gmail.com>
To: "Ljiljana" <ljiljana at fesb.hr>
Cc: <grasslist at baylor.edu>
Sent: Wednesday, October 13, 2004 3:09 PM
Subject: [GRASSLIST:4520] Re: grass and Mapserver
> On Wed, 13 Oct 2004 11:03:16 +0200, Ljiljana <ljiljana at fesb.hr> wrote:
>> Hi everyone!
>> I am trying to start grass mapserver demo,  with  spearfish location for
>> some time and i realy don't know what else to do.
>> I am using :
>> linux suse 9.0 with apache2 web serever, PHP 4.3.9 configured as CGI,
>> libgrass5-1.0.0,
>> gdal 1.2.3 configured with-libgrass
>> mapserver -4.2.3 configured wit folowing arguments:
>> ./configure  --with-eppl --with-threads --with-proj
>> --with-gdal=/usr/local/bin/gdal-config --with-ogr=/usr/local/bin/gdal-config
>> --with-php=/root/php-4.3.9 --with-gd=/usr/local  --with-freetype=/usr/bin
>> --with-pdf
>> I have installed grass57 and i copied .grassrc57 i htdocs directory, but
>> I
>> still recive message
>> msDrawMap(): Image handling error. Failed to draw layer named 'soils'.
>> msDrawRaster(): Image handling error. Unrecognized or unsupported image
>> format
>> drawEPP(): Image handling error.
>> /srv/www/grassdata/spearfish/PERMANENT/cellhd/soils is not an EPPL file.
>> when I try to display soils layer directly from the grass location.
>> All other layers are displaying corectly.
>> I get the folowing outputs for the tests
>> #./mapserv -v
>> MapServer version 4.2.3 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
>> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=EPPL7 INPUT=OGR INPUT=GDAL
>> INPUT=SHAPEFILE
>>  # ldd /usr/local/lib/libgdal.so
>>         libodbc.so.1 => /usr/local/lib/libodbc.so.1 (0x4032c000)
>>         libxerces-c1_6_0.so => /usr/local/lib/libxerces-c1_6_0.so
>> (0x4038a000)
>>         libpthread.so.0 => /lib/i686/libpthread.so.0 (0x405b7000)
>>         libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40609000)
>>         libpng.so.3 => /usr/lib/libpng.so.3 (0x40629000)
>>         libgrass5.so.0 => /usr/local/lib/libgrass5.so.0 (0x40657000)
>>         libz.so.1 => /lib/libz.so.1 (0x406dd000)
>>         libdl.so.2 => /lib/libdl.so.2 (0x406ec000)
>>         libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x406ef000)
>>         libm.so.6 => /lib/i686/libm.so.6 (0x407b0000)
>>         libc.so.6 => /lib/i686/libc.so.6 (0x407d3000)
>>         libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40906000)
>>         /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x80000000)
>>         libnsl.so.1 => /lib/libnsl.so.1 (0x4090e000)
>>  # /usr/local/bin/gdal-config --formats
>> gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem
>> jdem
>> envisat elas fit vrt usgsdem l1b nitf bmp pcidsk bsb gif jpeg png grass
>> What else could go wrong??
>> best regards
>> Ljiljana Bodrozic
> Try renaming the .grassrc57 in htdocs to just ".grassrc5" or ".grassrc"
> Richard Greenwood
> www.greenwoodmap.com
