[GRASSLIST:4544] r.fillnulls doesn't fill nulls
Maciek Sieczka werchowyna at pf.pl
Thu Oct 14 17:56:54 EDT 2004
hello!
in the precompiled 5.7 09_10_2004 r.fillnulls doesn't fill nulls for me
what is the reason?
example:
r.fillnulls input=dziurawy output=latany
Using tmp file r_fillnulls_2404
percent complete:   100%
WARNING: Raster is not CELL, '-v' flag ignored, raster values will be
         written to the table.
WARNING: Default driver / database for vectors set to:
         driver: dbf
         database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
WARNING: Database connection (for db.* modules) set to:
         driver: dbf
100%
Building topology ...
Registering lines:
114 primitives registered
Building areas:    98%
0 areas built
0 isles built
Attaching islands:
Attaching centroids:    98%
Topology was built.
Number of nodes     :   114
Number of primitives:   114
Number of points    :   114
Number of lines     :   0
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
Interpolating 114 points
Note: Below warnings may be ignored.
Percent complete: Reading lines from vector map ...    100%
Reading nodes from vector map ...    100%
 100%
Warning: strip exists with insufficient data
WARNING: 114 points given for interpolation (after thinning) is less than
given NPMIN=200
Warning : there is less than 400 points for interpolation, no segmentation
is necessary, to run the program faster, set segmax=400 (see manual)
Processing all selected output files
will require 141704 bytes of disk space for temp files
Percent complete:    100%
Note: Above warnings may be ignored.
Patching fill data into NULL areas...
r.patch: percent complete:    100%
CREATING SUPPORT FILES FOR latany
Filled raster map is: latany
