[GRASSLIST:4550] Re: grass and Mapserver
Ljiljana
ljiljana at fesb.hr
Fri Oct 15 04:13:42 EDT 2004
So, if I understood it right, grass aplication does not have anything to do
with mapserver. Mapserver comunicates with grass-gis layars only using
libgrass.
I have read something about changes in gdal-1.2.3 ( I had to configure
it --with-libgrass, not --with-grass, as later versions).
Can Mapserver with gdal-1.2.3.work with grass without libgrass (somehow
colecting the libraries for displaying grass directly from the grass) ?
Best regards
Ljiljana Bodrozic
----- Original Message -----
To: "Ljiljana" <ljiljana at fesb.hr>
Cc: <grasslist at baylor.edu>
Sent: Friday, October 15, 2004 9:24 AM
Subject: Re: [GRASSLIST:4530] Re: grass and Mapserver
> On Thu, Oct 14, 2004 at 08:36:44AM +0200, Ljiljana wrote:
>> Thanx!!!
>> I have already tried that, with all other combinations (.grassrc in www ,
>> grassrc with all permisions in htdocs, , grassrc in database folder...) .
>> I
>> dont know what is the difference now, but now it works.
> As you are using 'libgrass', the name must be .grassrc5 (as suggested by
> Richard).
> A 'grep' in libgrass source code reports:
> ./gis/gisinit2.c: * In this case put .grassrc5 into the DOCUMENT_ROOT
> directory
> ./gis/gisinit2.c: sprintf( gisrc, "GISRC=%s/.grassrc5",
> getenv("DOCUMENT_ROOT") );
> getenv("HOME") );
> I have now unpacked the README:
> http://grass.itc.it/spearfish/README
> ".grassrc5: contains LOCATION and MAPSET and DATABASE definition for
> SPEARFISH
> - put in /usr/local/httpd/htdocs/
>> Now I will be afraid to change anything :)
>> Thank you once again
> Good luck
> Markus
