[GRASSLIST:4556] Re: compiling GRASS 5.7.0
Markus Neteler
neteler at itc.it
Sat Oct 16 08:11:02 EDT 2004
On Fri, Oct 15, 2004 at 03:39:21PM +0100, Glynn Clements wrote:
> Ulrich Leopold wrote:
> > The "const" is missing in "null-val.c". Can I simply replace e.g. all
> > "CELL" by "const CELL" etc.?
> The "const" was added on 2004/07/23, (revision 1.9 of null_val.c)
> which suggests that your 5.3 source tree isn't up to date. Maybe
> whoever generated the grass53_exp_2004_10_09 snapshot had a sticky
> tag?
> The current revision of that file is:
> /null_val.c/1.11/Mon Oct 4 17:03:31 2004//
I just checked the grass.itc.it site:
bash-2.04$ grep grass_cvs_53exp_pserver_latest cron_*
cron_build_grass53bins.sh:GRASS53SRCDIR=/grass0/neteler/grass_cvs_53exp_pserver_latest
bash-2.04$ cd /grass0/neteler/grass_cvs_53exp_pserver_latest
bash-2.04$ cd src/libes/gis
bash-2.04$ pwd
/grass0/neteler/grass_cvs_53exp_pserver_latest/src/libes/gis
bash-2.04$ grep null CVS/Entries
/null_val.c/1.11/Sat Oct 9 05:10:15 2004//
^^^^- ok
I am quite sure that the CVS snapshot on "my" server is ok.
> If the snapshot includes the CVS directories, check the file
> src/libes/gis/CVS/Entries (in 5.3). If that's correct, check that the
> symlinks in the 5.7 tree point to the correct 5.3 tree.
> Glynn Clements <glynn.clements at virgin.net>
Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
