[GRASSLIST:4592] Re: Datum transform frustrations
Joel Peter William Pitt
pittj2 at lincoln.ac.nz
Thu Oct 21 23:06:34 EDT 2004
Hamish wrote:
>>and for the destination map:
>>-PROJ_INFO-------------------------------------------------
>>datum : nzgd2k
>>towgs84 : 0.000,0.000,0.000
>>proj : tmerc
>>ellps : grs80
>>a : 6378137.0000000000
>>es : 0.0066943800
>>f : 298.2572221010
>>lat_0 : 0.0000000000
>>lon_0 : 173.0000000000
>>k_0 : 0.9996000000
>>x_0 : 1600000.0000000000
>>y_0 : 10000000.0000000000
>>-PROJ_UNITS------------------------------------------------
>>unit : meter
>>units : meters
>>meters : 1.0
>You might check against a test coordinate:
>Eastern entrance to Akaroa Harbour:
>NZMG projection w/ NZGD49 datum
> 2507512.60416667 5702150
>NZTM projection w/ NZGD2k datum
> 1597502.78125 5140557.1875
>Lat/Lon w/ WGS84 datum
> 172:58:08.07E 43:53:17.0925S
>(give or take a few meters)
>You should definitely get the LINZ vector coastline from NZTopoOnline:
> http://www.nztopoonline.linz.govt.nz
>(Uses Arc/Web so horribly slow and mostly unusable... but you can
>extract shape files eventually)
>those are provided in NZTM/gd2k and you can figure out what's right and
>what's wrong from there.
Thanks Hamish :)
Okay, I extracted the region around Akaroa from NZTopoOnline and
overlaid it. One of my files was significantly off.
Now I have a slightly different (or maybe related) problem:
The projection co-ordinates match when I use "d.where -d -w"
for both nzmg and tmerc projections, but the longitude and
latitude is way off (approximately, if not exactly, the same for both):
172.96917306E 43.87039362S
When I use ArcMap it shows the same coordinates, but the correct
lat/long values.
Joel
