[GRASSLIST:4610] (no subject)
Ann Marie Gorman
amg24 at case.edu
Fri Oct 22 09:34:10 EDT 2004
Hello.
The University for which I work has recently changes our outgoing email
addresses and I cannot seem to post or unsubscribe to the list. Could
you please advise me as to how to either unsubscribe or have my email
changed in your database?
I could have subscribed as any of the following emails:
> amg24 at po.cwru.edu
> amg24 at case.edu
> amg24 at cwru.edu
> ann.gorman at case.edu
> ann.gorman at cwru.edu
Thank you for you help.
Ann Marie
|UNSUBSCRIBE GRASSLIST
amg24 at cwru.edu: You are not subscribed to list GRASSLIST at baylor.edu
If you wish to contact a person, please send mail to
GRASSLIST-request at baylor.edu.
To get general help on Listproc, please send the command:
HELP
in the body of the message to listproc at baylor.edu.
PS: Any subsequent requests you might have submitted in the same message
have been ignored.
On Thu, Oct 21, 2004 at 02:41:01PM -0400, Ann Marie Gorman wrote:
>> Thanks for your help...Please see below..
>> Markus Neteler wrote:
>>> >On Thu, Oct 21, 2004 at 12:17:22PM -0400, Ann Marie Gorman wrote:
>>>> >>Hi Markus.
>>>> >>Thank you for your help thus far.
>>>> >> 1. <>I still cannot post/unsubscribe to the listserve even though
>>>> >> Icreated a new account with my old email address and have
>>>> >> attempted to email:
>>>> >> <>grass at baylor.edu
>>> >This address is dead. Where did you find it?
>> I got both of these email addresses from the original "Greetings and
>> welcome to the GRASS GIS Users List! " message that I received when I
>> subscribed.
OK, this is not bad.
>>>> >> for help but my emails get bounced back b/c I am not on the list.
>>>> >> Any advice?
>>> >This addess is even not right (where did you find that?).
>>> >Please follow these instructions:
>>> >http://grass.itc.it/support.html#int_list
>>> >"To subscribe to the GRASS Users List, send email to: listproc at baylor.edu
>>> > In the body of the message, write the command:
>>> > subscribe GRASSLIST [your e-mail address]
>>> > (don't use the []'s)
>> I don't want to have 2 subscriptions so I tried:
>> unsubscribe GRASSLIST amg24 at cwru.edu
Yes, but you have to write from the account which was used
to subscribe! Hint: Set a fake 'From' sender in your mail program,
using the old address 'amg24 at cwru.edu'. But why do you worry about that?
The list software will disable that subscription automatically
if no longer valid.
>> got an error and sent an email to lpmanager at baylor.edu
I guess that's useless as probably nobody reads there
(I never got responses the last years).
>>>> >> 2. I still cannot export the Elevation attributes for my DLG...I have
>>>> >> done these steps:
>>>> >> * v.in.ogr ouput=hp07 dsn=hp01catd.ddf type=line 'when i do
>>>> >> d.what.vect I can see the cat and elevation data for each line
>>>> >> * v.db.connect -p hp07 'shows that tables are connected via
>>>> >> key=cat
>>>> >> * v.out.ogr hp07 dsn=tmp layer=hp07s format=ESRI_Shapefile
>>>> >> field=1 type=line
>>>> >> * My attribute tables comes out empty...This is the first time
>>>> >> I am trying to use the new database functionality, so please
>>>> >> bear with me! My goal is to export at least the cat field so
>>>> >> that I can join the table manually in ArcView.
>>> >A question for the list... Please try again. as European I use SDTS rarely,
>>> >Markus
>> Sounds good I will give it a try once I hear back from
>> lpmanager at baylor.edu...
May take a few years.
What's more important: Don't you receive the list mails?
Or: why not simply writing your problem to
grasslist at baylor.edu
and see what happens?
Markus
Ann Marie Gorman
Research Assistant
Department of Biology
Case Western Reserve University
10900 Euclid Ave.
Cleveland, Ohio 44106
Ph: 216.368.3579
Fax: 216.368.4672
Email: amg24 at cwru.edu
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20041022/dcd8f344/attachment.html
