[GRASSLIST:4615] v.out.ogr attributes
Ann Marie Gorman
amg24 at case.edu
Fri Oct 22 14:22:04 EDT 2004
Ok. It appears that I can subscribe now! Sorry about that....
Hi List.
I'm looking for help with v.out.ogr.
The goal is to import SDTS DLGs into GRASS and export them as
ESRI_shapefiles WITH the Elevation attribute information. Ultimately I
would like to create a scriptt o do many files (all 50 that I have).
I still cannot export the Elevation attributes for my DLG...I have
> >> done these steps:
> >> * v.in.ogr ouput=hp07 dsn=hp01catd.ddf type=line 'when i do d.what.vect I can see the cat and elevation data for each line
> >> * v.db.connect -p hp07 'shows that tables are connected via key=cat
> >> * v.out.ogr hp07 dsn=tmp layer=hp07s format=ESRI_Shapefile field=1 type=line
> >> * My attribute tables comes out empty...
This is the first time I am trying to use the new database functionality, so please bear with me! My goal is to export at least the cat field so that I can join the table manually in ArcView.
Thank you so much for any advice!
Ann Marie
amg24 at case.edu
