[GRASSLIST:4632] Re:Re: mask in grass57
Michele
michele.rocc at libero.it
Mon Oct 25 07:39:32 EDT 2004
Ok, thats works!! , Thanks, Michele.
> > is it possible to create a raster mask in grass57? It seems the
> > command is not present.
> Sure.
> Use g.copy, g.rename, or r.mapcalc MASK='...' to create a raster map
> called 'MASK' with areas to be left out set to 0 or NULL.
> g.remove or g.rename the MASK map to turn it off.
> Hamish
____________________________________________________________
Libero ADSL: navighi gratis a 1.2 Mega, senza canone e costi di attivazione.
Abbonati subito su http://www.libero.it
