[GRASSLIST:4676] Re: gshhs
    Ian MacMillan
    ian_macmillan at umail.ucsb.edu
    Thu Oct 28 21:03:26 EDT 2004
Hi all, thanks for the suggestions.
Unfortunately I can't quite get any of them to work.  I tried to remove
the dig_atts file then running v.convert and let it run for half an
hour without ever reaching 2% finished.  Next thing I tried was to
export the gshhs file from 5.3 as a shape file.  I am not quite clear
how I get the labels (from the dig_cats) file to be part of that shape
file.  The command I used was:
v.out.shape type=line map=gshhs_l
The resulting shape file has all the geometry, but no labels associated
with the lines when I import it back into 5.7
I also tried to import the shape file from NOAA, but it does not
contain the labels layer.
I am sure there is a way to do this.  I am figuring I need to figure
out how to export a shape file with the dig_cats file information
attached to it somehow, OR I need to just turn a dig_cats file into a
database after importing the geometry with v.in.ascii.
Thanks,
Ian
On Oct 28, 2004, at 1:25 AM, Radim Blazek wrote:
> Delete dig_atts in 5.3.
> Radim
> On Tuesday 26 October 2004 21:25, Ian MacMillan wrote:
>> Hi all, I have imported the gshhs (full resolution) vector shoreline
>> into a latlong location using Grass 5.3 without problems.  I would now
>> like to bring it into 5.7.  The v.in.gshhs command is not available as
>> near as I can tell with 5.7, so I am trying to use v.convert to go
>> from
>> 5.3 vectors to 5.7.  The problem is that I have let v.convert run for
>> 18 hours now, and it says that it is only 4% done with attaching
>> categories.  Something seems wrong here.  Has anybody imported gshhs
>> full resolution data into 5.7?  How did you do it?
>> Thanks,
>> Ian
>> PS I am running on mac os 10.3.5 with 5.7 from Lorenzo Moretti's site,
>> from roughly May, 2004.
