[GRASSLIST:4694] Re: Finding no r3.mkdspf and r3.showdspf files in winGRASS 5.7
Huidae Cho grass4u at gmail.com
Fri Oct 29 17:29:33 EDT 2004
OK, I've built both 5.3 and 5.7 without fftw support because grass
requires the old version of fftw. By the way, can I put all the
binaries of the modules including r.terraflow in a binary
distribution?
Huidae Cho
On Fri, 29 Oct 2004 10:23:24 -0500, Huidae Cho <grass4u at gmail.com> wrote:
> Hi,
> On Fri, 29 Oct 2004 17:00:38 +0200, Markus Neteler <neteler at itc.it> wrote:
> > On Fri, Oct 29, 2004 at 10:51:06AM +0800, amos gong wrote:
> > > Hello,
> > > I have downloaded the Precompiled Binaries winGRASS 5.7 from this
> > > site(http://grass.baylor.edu//grass57/binary/mswindows_cygwin/)  and
> > > installed them following the instruction from this
> > > site(http://grass.baylor.edu//grass57/binary/mswindows_cygwin/cygwin_grass.html).
> > > After the installation was completed ,I wanted to try out the sample
> > > data set named "3D weather
> > > situation"(http://grass.baylor.edu//grid3d/grass5grid3d_sample.tar.gz)
> > > in this page(http://grass.baylor.edu//grid3d/index.html#sample).
> > Note:
> > We'll replace this data set as soon as possible with a better one.
> > The "3D weather situation" is not in sync with the current G3D status.
> > > But when I used the "r3.mkdspf" command , bash output "command no found"
> > > and I cannot find r3.mkdspf and r3.showdspf files anywhere.
> > > Is there anyone can do me a favor?
> > We'll have to find a volunteer to build a fresh winGRASS 5.7 package.
> I'm going to build a package.
> Coming soon! ;-)
> Huidae Cho
> > Markus
