[GRASSLIST:4307] Re: r.contour
Gordon Keith
gordon.keith at csiro.au
Sun Sep 5 21:17:20 EDT 2004
On Sun, 5 Sep 2004 17:34, Hamish wrote:
> > On grass-5.7.cvs-i686-pc-linux-gnu-28_08_2004 on debian
> > I tried to use r.contour on a kernel raster but I have this result:
> > GRASS 5.7.cvs:~ > r.contour input=fagiano_kernel step=0.00001 cut=0
> > output=fagiano_kernel
> > WARNING: The vector 'fagiano_kernel' already exists and will be
> > overwritten.
> > Reading data.
> > Percent complete: 100%
> > FPRange of data: min = 0.000000 max = 0.003658
> > Minimum level will be 0.000000
> > Maximum level will be 0.003650
> > Continue?(y/n) [y] y
> > Displacing data.
> > Total levels: 367 Current level:(it counts levels and then...)
> > Segmentation fault
> This works fine for me, can you make it fail with something from the
> spearfish dataset?
FWIW I've also had problems with r.contour segfaulting when producing large
numbers of contours on reasonably large datasets.
I don't remember the details, and it wasn't worth tracking it down, but I
think the work around was just to ask for less contours, then it would work.
My untested suspicion is that perhaps there is a list of nodes maintained in a
short array and it segfaults when you get more than 32K nodes.
Regards
Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine Research
http://www.marine.csiro.au
In theory there is no difference between theory and practice.
In practice there is.
