[GRASSLIST:4320] Re: grass maps via mapserver
Richard Greenwood richard.greenwood at gmail.com
Tue Sep 7 23:10:09 EDT 2004
Are you on Linux or Windows? Try
   gdalinfo --formats
to make sure gdal supports GRASS
put a .grassrc5 into the DocumentRoot location as defined in the
httpd.conf file.
(e.g. /usr/local/apache2/htdocs  or /var/www/html on Mandrake 9.0)
Also, the LAYER object DATA
element needs to reference the raster from the cellhd directory (e.g.
/data/grass/location/mapset/cellhd/mymap).
For me, the full path did not work, but when I put the .grassrc file
in /var/www/html I did not need to specify a full path.
Richard Greenwood
www.greenwoodmap.com
On Tue, 07 Sep 2004 16:37:26 +0300, temiz <temiz at deprem.gov.tr> wrote:
> hello
> I tried to get  grass maps via mapserver. But I couldn't
> and no error is received. Just map is not seen
> what might be possible problems ?
> regards
> Ahmet Temiz
> ______________________________________
> Inflex - installed on mailserver for domain @deprem.gov.tr
> Queries to: postmaster at deprem.gov.tr
> The views and opinions expressed in this e-mail message are the sender's own
> and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> of General Directorate of Disaster Affairs.
> Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
