[GRASSLIST:4336] Re: --with-gdal
Paul Kelly
paul-grass at stjohnspoint.co.uk
Fri Sep 10 04:49:45 EDT 2004
Hello Maciek
On Thu, 9 Sep 2004, Maciek Sieczka wrote:
> hi!
> can somebody please tell me if it is safe to build Grass 5.3
> (cvs) --with-gdal?
Of course it is safe!---this is the default. r.in.gdal probably will not
work if you specify --without-gdal
> I found some information on it but I'm confused
> I want the r.out.gdal in Grass work
r.out.gdal does not use the GDAL library so --with-gdal or --without-gdal
is irrelevant for it. It uses gdal_translate and you must compile GDAL with
GRASS support. Or a workaround is to use r.out.tiff to create a tiff
image together with world file, g.proj -wf to create projection information
and to merge them all together with gdal_translate. See the r.out.gdal script
for a hint on how to do this.
Paul
