[GRASSLIST:4338] v.to.db
    Leonardo Lami
    lami at faunalia.it
    Fri Sep 10 10:42:42 EDT 2004
I'd like to know if is it possible and how make this kind of operation in
Grass.
I have a vector linked to a table with this three fields: id, count, area,
value and I'd like to update the field "value" with the result of this
operation: "count" value / "area" value
I tried to use v.to.db:
v.to.db map=g_anfibi field=3 qfield=3 option=query col1=sum qcol="count/area"
but the output message say:
Reading data trom the map ...  100%
Querying database ... DBMI-DBF driver error:
SQL parser error in statement:
SELECT sum(valore) FROM g_anfibi WHERE cat = 1
Error in db_open_select_cursor()
I tried also:
echo "UPDATE g_anfibi_sum SET sum=count/area" | db.execute
Error in db_execute_immediate()
WARNING: Error while executing: "UPDATE g_anfibi_sum SET sum=count/area
Which is the best solution?
Thanks
Leonardo Lami
lami at faunalia.it            www.faunalia.it
Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy   Tel: (+39)349-1310164
GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
https://www.biglumber.com
