[GRASSLIST:4364] Re: applying raster heightmap to vector file z value
Benjamin Mesing benjamin.mesing at rostock.zgdv.de
Fri Sep 17 11:56:22 EDT 2004
> Such module is not yet written. For points, you can use
> v.what.rast + v.in.db.
Thanks - at least I know now, that there is a difference between vectors as
points and as lines.
To bad that there is no such module yet as it should be nearly identical to
v.what.rast if one would not subdivide the lines.
Greetings Ben
