[GRASSLIST:4373] Re: Setting GRASS environment variables in c-shell script
    Sandro Klippel
    sandroklippel at yahoo.com.br
    Fri Sep 17 17:08:51 EDT 2004
PATH ?
setenv PATH /path-to-grass/bin:/path-to-grass/scripts
Em Sex 17 Set 2004 17:17, você escreveu:
> I'd like to run some GRASS commands externally through a c-shell script.
> In other words, have the script start up GRASS, run a function, then
> close GRASS. As I understand it, I need to set the GRASS environment
> variables first, then I can start executing GRASS commands...but I'm
> having trouble doing that. Can anyone identify something that may be
> causing this script to not work (i.e. all I get is: "g.list: Command not
> found" when I run it):
> #!/bin/csh
> echo "GISDBASE: /home/dad/grass"                     > $HOME/.grassrc5
> echo "LOCATION_NAME: POLARS"                         >> $HOME/.grassrc5
> echo "MAPSET: stage4"                                >> $HOME/.grassrc5
> echo "DIGITIZER: none"                               >> $HOME/.grassrc5
> echo "GRASS_GUI: text"                               >> $HOME/.grassrc5
> setenv GIS /usr/local/bin/grass5
> setenv GISBASE /usr/local/bin/grass5
> setenv GISDBASE /home/dad/grass
> setenv GISRC /home/dad/.grassrc5
> setenv LOCATION /home/dad/grass/POLARS/stage4
> setenv LOCATION_NAME POLARS
> setenv MAPSET stage4
> g.list rast
> exit
> Thanks much!
> -Tye Parzybok
> Tye W. Parzybok, President
> Metstat, Inc.
> Windsor, Colorado
> voice: 970.686.1253
> fax: 208.728.7256
> email: tyep at metstat.com
> web: www.metstat.com
Instituto IGARÉ
http://geocities.yahoo.com.br/institutoigare
e-mail: institutoigare at yahoo.com.br
