[GRASSLIST:4386] Re: create a network
Radim Blazek
blazek at itc.it
Tue Sep 21 09:31:48 EDT 2004
On Tuesday 21 September 2004 11:02, Leonardo Lami wrote:
> Hi,
> I have an area polygonal vector and I'd like to create a network between
> its elemnts. It is possible to create a network where the linking lines are
> the minimum distances between the boundaries of the nodes?
> Thanks to all the list
Not sure if it is what you want, I have a module doing this
(the red line generated from green+blue):
http://mpa.itc.it/radim/g51/v.area.path.png
It is not finished, I can send it to you, but without any additional support.
Radim
